OK, so I'm going cross-eyed reading all the chlorine posts on here! I have a question that I haven't found covered yet.
First of all, I just had my pool renovated. Fiberglass walls were removed and replaced with shotcrete and the whole pool was plastered. Pool was filled with city water (pretty good) last week. PB added some CYA and level just now is on the low side of normal. Chlorine was added and that's where the confusion starts. I hava an OTO test which shows chlorine to be 3-5 (a little higher than I would like at the moment). When I use the HTH test strips, it shows combined chlorine to be VV low and free chlorine to be low (about 0.5-1 as best as I can tell). PH is 7.6. Which shoulde I believe? I'm inclined to believe the OTO test.
Also, the OTO test kit says read the color after 5 seconds and this is free chlorine; Wait 5 minutes and read again and this is total chlorine. I take it that this is..... shall we say....... errrr....... optimistic?
