- Jun 7, 2017
- 9,159
- Plaster
- Jandy Aquapure 1400
I did this. ♀A watched pool never fills, they say. But turn your back for a SECOND........
Mee tooo! Hence the warning about a timer!I did this. ♀
For future reference if you didn't, or for anyone following, always Overnight Chlorine Loss Test before raising CYA in the spring. SLAM FC is 40% of the CYA and you'd much rather SLAM at 12 FC than 28.For the pool bringing CYA up hopefully to 60 then 70
good to know. I was steady at 9FC for several days then dropped to 5.5 after leaving my cover open for a few days in the bright sun. Water has been crystal clear after the robot did its thing. Hope when I test shortly its still at 5.5. I just turned the SWG on.For future reference if you didn't, or for anyone following, always Overnight Chlorine Loss Test before raising CYA in the spring. SLAM FC is 40% of the CYA and you'd much rather SLAM at 12 FC than 28.
Well, I'm glad I pumped about 4 inches out of the pool yesterday, because we just got about 3 more this morning *sigh*
My neighbour is working on a temporary pool too. That's actually where the 'creek' empties into the main tributary...just overwhelmed with the rain the last couple days.
Bush, tree, bush, drain - drain is about 18 inches deep...you can just about see the shadow of the top of it....
We opened the pool on Saturday. The water temp was 46. We're going to have a sunny warm week in NY in the 70s and 80s and we wanted to hang by the pool if just to have the glittering water for ambience. I bet the dog will decide it's not too cold to swim. The pool opened up clear and mostly clean. Needed a quick vacuum and a brushing, but the tabs in two floaters attached to a line across the pool held some chlorine over the winter. PH drifted up and a 1/2 gallon us muriatic acid brought things into line. The season has begun!KFLG is 7014’ it rises up quickly through the Coconino National Forest
I'm also unable to resist peeking under the covers - looks sparkly...I peaked under the cover yesterday and water is almost to normal levels and i can still see the bottom.
