Ok great, thanks for the heads up. I'll time the buckets again and double check.That should work. The theory is to minimize the mixing. Looks like more than 5 gpm.
I timed again and it was 1:12 to fill 5 gallon bucket for refilling hose, and 58 seconds to fill 5 gallon bucket with effluent hose.That should work. The theory is to minimize the mixing. Looks like more than 5 gpm.
That is good. Likely could leave the basket in, but just remember to replace it when done.I took the skimmer basket out, and put the hose down into the PVC of the drain... is that right?
Perfect, will do. I guess I should turn the floor returns in the deep end off as well, and just the shallow ones on, if the fresh water is going into the plumbing. Also, it looks like it might rain. The Draining - Further Reading article didnt mention anything really re: weather if not draining completely and then refilling. Rain ok?
Floor returns? Be sure those are isolated. Or this entire thing will be a flop.Perfect, will do. I guess I should turn the floor returns in the deep end off as well, and just the shallow ones on, if the fresh water is going into the plumbing.
Your pool pump should be off as well.This is what I set for my plumbing valves, with the fill hose in the shallow skimmer pipe.
Yep, everything is offYour pool pump should be off as well.
How are your floor returns working without a pump?Yep, everything is off
they're not working - maybe I'm doing this for no reason. My thinking was that the filling hose could push water up through the plumbing since its flowing water into the skimmer pipe, and flowing up into the filter - so if that was the case, then the water that is coming back out and through the returns, is only coming through shallow end. If the filling hose isnt actually going to do that, then thats even better.
No, you don’t want that. You want a single source of water going in as far away as possible from the source of water going out. Shut the returns off and don’t try and push it through the plumbing.they're not working - maybe I'm doing this for no reason. My thinking was that the filling hose could push water up through the plumbing, back through the filter - so if that was the case, then the water that is coming back out and through the returns, is only coming through shallow end. If the filling hose isnt actually going to do that, then thats even better.
Ok, I'll turn everything to off position. Should I push the hose down into the skimmer piping pretty far? If everything is in off position (and pump off), then that would be as far away as possible? Or am I getting carried away.No, you don’t want that. You want a single source of water going in as far away as possible from the source of water going out. Shut the returns off and don’t try and push it through the plumbing.
You don’t -need- to push it into the piping at all. Water getting sucked out of the bottom of the pool and water entering at the top with as little splashing, current as possible.Ok, I'll turn everything to off position. Should I push the hose down into the skimmer piping pretty far? If everything is in off position (and pump off), then that would be as far away as possible? Or am I getting carried away.
Sorry for all the questions.. but thank you again
