Worn out wire to light
Oct 15, 2017
4
Houston/Texas
Did not notice the split in the insulation of the submerged wire until I had replaced the bulb and cover gasket..
Hoping someone might know where I can buy just the housing part with the wire. Local supplier (and online sources I've checked) sell only complete assembly.
Hi RoxyandGil,
Could you supply me with the make, model, voltage and wattage of your light? Also if you have any part #'s or if you could post a photo to this thread that would be quite helpful.
Hi Kim and thanks
i just thought giving the exact size of the thing would describe it sufficiently.. since they're so basic..
and the brand that it either is, or that it genericizes (pentair)
conical in shape, like I think they all pretty much are with the power cable penetrating thru a sealing grommet.
I will happily consiser becoming a "supporting member" if this resource turns out to be helpful
You can use fliker or such. Make sure to use the IMG code so they are in the post. You could also become a supporting member as seen at the top of the page and host them here.
Kim:kim:
