Normal dirt will collect in dips in the pool floor, just vacuum it up. Just let the FC drop to the top of your normal daily target range to test the pH. You need a little CH, around 50 ppm for a vinyl liner pool. If you have a heater you may need a little more. Your manual should say how high CH should be. If your water is so soft it foams raising the CH a little should help cut that down.
