I have recently bought a wood-fired hot tub and I am voraciously reading posts here and elsewhere about water treatment. There's a lot of (mis)information around and I would hugely appreciate any advice.
I only intend on using the tub once or twice a month and while it always needs to be full of water so the wood remains watertight I am happy to drain and refill before each use. I don't mind bathing in fresh, untreated water; my only concern is keeping algae and mould at bay after each dip and before the next water change.
The manufacturer has advised me not to use chlorine in the tub and has instead advised that I use active oxygen and silver ions because it will be less harsh on the wood. Can this be right? Surely any oxidiser will attack the wood at sufficient concentration and so it is less about which chemical I choose and more about the amount I use?
Do I even need an oxidiser if I'm going to be draining and refilling every 2-3 weeks before each dip? Could I just use an algaecide?
