Hoping someone might be able to assist confirming a few questions...
1. Should I connect the Pump, Heater and SCG all to the same 220v 20amp GFI in my ET or should I separate the power to any of them?
2. If I use the same breaker, would I use only one (pump?) relay and connect all loads to that relay or daisy chain the line sides to 3 different relays in order to separate the loads?
3 If only one relay is used would that connect to the Pump port on the control panel side so that all elements are powered when the pump is on?
Since each element has an independent low voltage control connection, it seems to me that one relay would work. And as long as the pump is powered on the heater and SCG would be powered.
Thanks for any help!
PS the manuals are terrible
