- May 30, 2012
- 1,618
- Plaster
- CircuPool Edge-40
I currently have a t106 and t104 timer controlling 2 speed 1.5 HP whisperflo, and Stenner. Should be receiving 1.5hp Superflo VS tomorrow. I should be able to do away with the t106 timer, and use the t104 for the Stenner. No need to run the VS through a timer, right? Just hook up to black and red incoming hot lines (and ground). So white neutral it's no longer needed for anything, right? Just cap it off?
No need for the current freeze protection circuit, right? It's built into the VS.
