- Aug 4, 2016
- 4
- Plaster
- Pentair Intellichlor IC-20
My pool does not have automation and from what I've been reading its not recommended to trust the flow switch to shut swg off. So I'm going to install the intermatic T104 timer seeing how when the pump stops per schedule the swg is still active. Question is do I wire both the pump and the swg to the timer? If so is there a wiring diagram available? Thank you
