I hope this is the right place to post this question, I am new to the forum... I have been creeping around looking for the answer, but there seems to be a couple of different answers. My pool build is almost done, I am doing the electrical myself. I have Pentair Easytouch 8 control panel, intelliflo vsf pump, mastertemp 400 (gas), and polaris booster pump to run my cleaner.
My main question is I realize the vs pump needs constant power, do i wire direct to the breaker then take it over to the relay or do I go direct to the relay from the pump and wire it hot from the breaker?
For the heater, I know I need to tap into the firemans switch and run that on the low voltage side to the "gas heater" port. Is it also necessary to power the heater direct to the same 2 pole breaker as the filter pump?
I also have a second 2 pole siemens 20 amp breaker that I plan to dedicate to my polaris booster pump.
I really appreciate the help, thanks!
