wiring Elfin-EW11 to Pentair Easytouch
I just installed an Elfin EE11 into my IntelliCenter (using the spare ethernet port on the WiFi bridge). I only had to change two settings to get it working.
<UART key='Baudrate' value='115200'>
<UART key='FlowCtrl' value='Disable'>
---TO---
<UART key='Baudrate' value='9600'>
<UART key='FlowCtrl' value='Half-Duplex'>
EDIT: Also changed timeout value from 0 to 300 for TCP Server, which changed it from disabled to 5 mins.
Has anyone else noticed that when njsPC is running that the web admin interface on the Elfin is slow or doesn't work? I assume this is because the TCP socket used by njsPC is consuming the limited resources on the embedded device. Not a deal breaker but I wanted to see if others had the same issue.
EDIT: The datasheet shows the EE11 has weaker specs than the EW11 which could account for the slowness.
