Hi mknauss, I have a similar question around this as I have a VS pump and use the onboard scheduler instead of the timer I had before I got the VSP. I am about to get a SWG and was wonder if I could wire directly into the VSP?You should not wire a VS pump that way. VS pumps should get continuous power to them and use the onboard scheduler for pump run times.
Thanks.
