Hello - I am doing advance research to assist my electrician in wiring the following devices:
1. Intermatic RC2343PT timer (note: blower & freeze protection functions will NOT be used or connected)
2. Homeline 2-pole 20A 120/240 GFI 60Hz circuit breaker (two hot legs + neutral)
3. Pentair 1.5 HP 230v 2-speed pump (model# 340043) 1PH 60Hz
Assumptions regarding the wiring:
A) breaker neutral wire connects to timeclock white wire
B) one breaker hot line wire connects to timeclock black wire
C) other breaker hot line wire connects to pump terminal #1 (per pump diagram)
D) breaker ground wire connects to pump & timeclock ground wires
E) timeclock blue wire (hi-speed) connects to pump terminal #2 (terminal #2 is hi-speed per pump diagram)
F) timeclock gray wire (lo-speed) connects to pump terminal #3/4 (terminal #3/4 is lo-speed per pump diagram)
Also, Is GFI breaker needed?
Thank you!
Thank you!
