- Oct 19, 2018
- 143
- Plaster
- CircuPool Universal40
What do you folks do after closing during the winter months? Last year my pH after closing soared, resulting in a lot of scaling. (New plaster, so that's a bit understandable.) I want to avoid that situation this year.
I have a Looploc mesh cover. Assuming the water isn't frozen, which in Maryland I don't expect it to be, how would I test and if need be add any chemicals? Muriatic acid is likely what would be needed, so obviously it needs mixing! Related - before closing should I drop the pH to the lower end of the range? It's pretty stable at 7.5 now that the plaster is a year old.
