Windows control panel
If you drag (with the right mouse button) the control panel icon to your desktop, it will give you the option to create shortcut here.
Hope this helps.
Another method (assuming you are using Windows) is to right click on the desktop, select NEW and then SHORTCUT. Navigate to C:\Windows\System32\Control.exe and then select it.
That will give you a direct link to Control Panel.
