Sonoff Pool Automation Help Needed
judge99
1
Cleveland
@FloridaGary do you have a picture of how you wired this up? I have the same setup - Sonoff 4CHPro - Black and Decker Pump and the Smart panel for it. Looking to wire up the Sonoff so I can control the speeds of the pump remotely. Just want to make sure I am wiring this thing properly before I start.
Welcome aboard Judge! You've come to the right place for expert advice that is never conflicted because we don't sell anything. Just real experts and pool enthusiasts that volunteer to help pool owners. I've looked at using all of what I call 2nd tier pumps but never used them. What kind of control are you looking to achieve? I believe the B&D pump you are using is programmable with it's internal timer so you can set this to power up with that is set and run as an "on-off" type of automation but if you want to trigger digital input control where your automation system can call a preset speed and run it for a time determined by the automation separately you an adapter like the one shown below. Please add a signature to help us be more efficient with our volunteers time and help you get answers more quickly. Here's how.
I hope this helps and I'll be following this closely. I always like to see innovative approaches to automation!
Chris
