kmerenda
4
Houston, TX
I recently upgraded my pool/spa electrical to an Intellicenter load center ips5. Before the upgrade, the spa had an air button to trigger the blower. The blower automatically flipped on following any power outage, so I was happy to wire it straight in to an intellicenter relay. I do miss having easy push-button access to the blower. I was wondering if I could retrofit my air button to an IS4 spa remote? There is 1/2 inch conduit extended about 3/4 inch past the tile, and the coping overhangs about just as far. I know the IS4 needs a 1 inch receiving pipe. What do you think? Would it work, or would it stick out so far it would be a nuisance?
If you cut back the 1/2" pipe at the wall and then glue in a 1/2"x1" adapter, you can see if the IS4 fits right on the adapter or if you need to put a 1" pipe on it. I think the ISA4 will fit right into the adapter. Depends on the depths.
You have to be willing to get the parts and see how it fits together.
  • iS4_Spa-Side_Remote_Control_Installation_and_Users_Guide_English1-1.pdf
