I currently have a single stage pump (Jandy SHPM 1HP). The pump sits about 4'9" above the water level and about 30' from the pool. I have measured the suction to be about 8"mg and the pressure about 10"mg (with the filter almost needing cleaning). It has two inlet pipes, one from the skimmer at 2" and the other slightly below the water line at 1.5", and has one outlet pipe at 2". I am considering replacing the motor with a 2 speed option and keep the wet side housing. My concern is with the pump sitting almost 5' above the water and 30' from the pool, will a 2 speed pump running on the low speed have enough speed/power to actually move the water?
