- Aug 8, 2024
- 274
- Plaster
- Pentair Intellichlor IC-60
The pool bonding grid should not be connected to any electrical grounds. It is a seperate grid.That copper wire actually runs to the ground bar in my panel.
Because it was tied into each pool accessory via the bonding lug and then into the concrete at the inlet pipe, I thought it was the bonding wire/bonding wire only.
Am I good to just add a jumper from my wire nut to the green screw/post in the timer box or do I need to run a jumper over from the green ground in the j box which is not bare/not tied into the bonding lugs?
If you look towards the back you’ll notice both green and bare copper to the terminals on the ground bar
So just jump it over from the other ground wire to be sure?
Both running to same ground bar but insulation could provide additional safety?
Since my "bonding wire" is tied into the CB panel ground bar...it's not actually a bonding wire or at least not correctly installed per NEC code for swimming pools?
Insulated vs. Bare Ground Wire Application
Hey All, I may be overthinking this one, but one of our interns asked about the application of bare ground wire vs insulated ground wire, and I can't stop second-guessing my answer. My gut response was that bare copper wire allows the user to connect to earth or other grid materials (thinking...forums.mikeholt.com
