J JayJay1 Member Mar 11, 2022 16 Tucson Az Pool Size 15000 Surface Plaster Chlorine Liquid Chlorine Feb 16, 2024 Add bookmark #1 So I open my app and it’s not showing rpm gpm or the watts. The pump is running like normal it’s just not reading data on the app. Last edited by a moderator: Feb 16, 2024
J JamesW TFP Expert Mar 2, 2011 51,756 Feb 16, 2024 Add bookmark #2 What does the pump display show? Is the system in Service Mode?
J JayJay1 Member Mar 11, 2022 16 Tucson Az Pool Size 15000 Surface Plaster Chlorine Liquid Chlorine Feb 16, 2024 Add bookmark #3 Like normal but I have always been able to see the information Last edited by a moderator: Feb 16, 2024
J JamesW TFP Expert Mar 2, 2011 51,756 Feb 16, 2024 Add bookmark #4 Normally, the display will say "Display not Active" when the remote controller is in control.
J JayJay1 Member Mar 11, 2022 16 Tucson Az Pool Size 15000 Surface Plaster Chlorine Liquid Chlorine Feb 16, 2024 Add bookmark #8 I can still change the rpm’s of the pump with the app just can’t see the information on the app. Maybe it’s my network.
J JayJay1 Member Mar 11, 2022 16 Tucson Az Pool Size 15000 Surface Plaster Chlorine Liquid Chlorine Feb 16, 2024 Add bookmark #10 I have no clue about the current controller but if you point me in the right direction to find out I can make it happen
J JamesW TFP Expert Mar 2, 2011 51,756 Feb 16, 2024 Add bookmark #11 Can you show what equipment you have at the equipment pad including any boxes on the wall?
J JayJay1 Member Mar 11, 2022 16 Tucson Az Pool Size 15000 Surface Plaster Chlorine Liquid Chlorine Feb 16, 2024 Add bookmark #12 I don’t have much Last edited by a moderator: Feb 16, 2024
J JamesW TFP Expert Mar 2, 2011 51,756 Feb 16, 2024 Add bookmark #13 https://www.pentair.com/content/dam/extranet/nam/pentair-pool/residential/automation/intelliconnect/manuals---user-documentation/users-guide/intelliconnect-link20-app-guide.pdf https://www.pentair.com/content/dam/extranet/nam/pentair-pool/residential/automation/intelliconnect/manuals---user-documentation/install-guide/intelliconnect-manual-english.pdf Attachments intelliconnect-manual-english.pdf 2 MB · Views: 0 intelliconnect-link20-app-guide.pdf 2.4 MB · Views: 0
J JamesW TFP Expert Mar 2, 2011 51,756 Feb 16, 2024 Add bookmark #14 You have IntelliConnect. What Mode is the IntelliConnect in?
J JamesW TFP Expert Mar 2, 2011 51,756 Feb 16, 2024 Add bookmark #15 It does not look like one of the Mode Lights is on?
J JamesW TFP Expert Mar 2, 2011 51,756 Feb 16, 2024 Add bookmark #16 Can you show a closeup of this RS-485 connector?
J JayJay1 Member Mar 11, 2022 16 Tucson Az Pool Size 15000 Surface Plaster Chlorine Liquid Chlorine Feb 16, 2024 Add bookmark #17 It was blinking but some reason it’s working now Reactions: JamesW
J JayJay1 Member Mar 11, 2022 16 Tucson Az Pool Size 15000 Surface Plaster Chlorine Liquid Chlorine Feb 16, 2024 Add bookmark #18 Thank you for the help and information Reactions: JamesW
