I have had this 15' by 52" (5000 gal) steel above ground pool (overlap liner) for about 3 years. This is my 4th spring start.
All the prior years my CYA would be zero starting out in spring. Winterizing routine is a cheap winter cover and lower water below return. I usually use liquid chlorine to slam level when I close for the winter. In the Spring chlorine is zero.
My CYA is 50. I have tested it multiple times. I even bought the refill kit to ensure it was not wrong. I also filled my tube with just pool water. Totally clear.
The reason I asked is I am battling green alage. I was slamming but I was treating CYA as zero. Obviously now I know it's supposed to be slammed with 50 cya.
Simple question why this year is cya still around?
