- Jun 7, 2017
- 10,000
- Plaster
- Jandy Aquapure 1400
In my estimation, based on info garnered here on the site, is that not only is the cost of running ones' VSP pumps 24/7 negligible, but it's likely more service-life-expectancy 'friendly' to let the pump continuously do it's thing vs having it turn itself off & on multiple times a day/week/yr. Hard to argue with guys here that have pumps that've been running continuously (in round #s anyway) for the better part of 10-years (or more).You can split hairs that he can reduce his costs by 1/3 running only 16 hours a day, or 1/2 by running 12 hours, but at $20 a month does anybody really care about $6-$10 for the total piece of mind it brings ?
Perhaps but I suspect it is far from a hard start like a 1 or 2 speed pump.Mine ramps up like it's a B-52 bomber jet engine being lit by explosives assist.
Is your pump set to auto prime up to max rpm at each startup? My system does not require priming after being off for 12 hours or more so I disabled this feature, and the ramp up is much less now. I have three speed / time settings and utilize a max rpm of 2200 rpm for the first and last settings and the 1300rpm for the middle and longest run schedule. Total peak run time in summer is 12 hours and 6 in winter.Mine ramps up like it's a B-52 bomber jet engine being lit by explosives assist.
DM, I too am a 100% pentair guy, anyway..I run mine 24/7...I like to keep it skimming/filtering.
I run 1700 RPM from 7AM till 10PM then drop back to 900 RPM from 10PM till 7AM
My SWG and pool cleaner run during the daytime higher RPM run. Been this way for the 7 months since I put the pool in and it works great for what I wanted to accomplish and does not cost much to run it this way.
I'm sure it is. Honestly I haven't messed with it as I didn't think there was a need to (I could be wrong though), thought being when the thing needs to re-prime it should do so quickly & with authority.Is your pump set to auto prime up to max rpm at each startup? My system does not require priming after being off for 12 hours or more so I disabled this feature, and the ramp up is much less now. I have three speed / time settings and utilize a max rpm of 2200 rpm for the first and last settings and the 1300rpm for the middle and longest run schedule. Total peak run time in summer is 12 hours and 6 in winter.
Yes I understand your position. I tested my system several times after opening and cleaning my filter to observe the result of priming the pump at 2200rpm and it worked fine. My startup rpm is 2200rpm so I am ok with disabling the auto prime.I'm sure it is. Honestly I haven't messed with it as I didn't think there was a need to (I could be wrong though), thought being when the thing needs to re-prime it should do so quickly & with authority.
If it works, it works.I tested my system several times after opening and cleaning my filter to observe the result of priming the pump at 2200rpm and it worked fine.
The days when people tried to get numbers-specific about pump run time, primarily for turnover, are no more. Today, we encourage pump run times for two simple reasons - surface skimming and chemical maintenance (i.e. SWG production, mixing chemicals, etc). If your VSP also powers a cleaner, then that would also apply, but that's really it.
Determine Pump Run Time
To figure out how many hours you need to run your pump, you need to know how fast your pump works. You can find this here.www.troublefreepool.com
I'm doing research to determine if I should swap out my 1HP single speed Hayward Super Pump with a VS pump. You say you have a high electric rate, how much are you paying per kwh?I do not run 24 hrs per day. I have very high electrical costs so 24 hr is a big bump in costs. In the summer, I run at about 1500 RPM, I have two skimmers which requires more flow rate, and for about 9 hrs per day, mainly for solar gain. In the winter, I run only two hours per day at the same 1500 RPM.
