Re: Please help us rid of $600-$850/m pool service!
The water is absolutely clear. Said even started getting the "glints" last week. It's just this pesky vacuuming thing.
If I was there to do it, SLAM would certainly be the way I would go. I hesitate to ask the tenant to have to do this, and likely can't afford to have the pool guy do it.
Bottom line, since the water is crystal clear, do I have ANY recourse other than SLAMing?
Looking at your posts, you have a few (long-distance) challenges such as:
- FC is definitely low. It should ideally hoover at the target of 4. When it drops below the minimum FC of 2 (based on your CYA of 30), that's when algae comes-in.
I was wanting the CYA at 40, but he has been adding stabilizer weekly for the past 3 weeks and this is as high as it's been yet (30 was easy to attain). Is this because the FC is low (because algae is eating it)?
- If you have algae in there now, then you need to SLAM via Pool School - SLAM - Shock Level And Maintain. This means someone will need to be there consistently throughout the day to add the required amount of bleach to "maintain" that higher SLAM/Shock FC level of 12 based on your current CYA. The FC must stay at 12 until you pass the 3 SLAM criteria listed on that SLAM page. No amount of vacuuming or filtering alone will resolve your problem. It must be SLAMmed.
Tenant works from home, so this seems reasonable to ask, but I'll have to check. I do hate to have to ask, but if they don't want the pool to be filled . . .
- We don't recommend using tablets/pucks. They raise your CYA to dangerous levels that, over time, become unmanageable. The longer you leave them in, the higher your CYA will go, which in-turn means your FC must also increase.
I'm ALLLLL about ridding of the pucks. Pool guy is hesitant. And right now, the CYA doesn't seem to be in danger, so I've let it be. Any harm at this point?
- Reinforce to whomever is watching your pool that they only use products recommend by TFP at Pool School - Recommended Pool Chemicals.
Somewhere along the line I told pool guy very little chems would be needed to do TFP and to avoid anything he didn't absolutely have to use. Hence, he wasn't using stabilizer. Hence, the CYA was never coming up. Hence the FC being so low.
If your water is not too bad right now, a proper SLAM may be completed in a week or less. But if the SLAM instructions cannot be maintained, the algae will not be killed. Hope this helps get you going. If you have any more questions, just let us know.
