I have a Hayward T15 cell less than 2 years old. I clean it regularly. after cleaning it this weekend and re installed it, the lights on the Aquaright controller continue to say Inspect cell, check salt I hold the button for the 3 seconds to reset the lights, and that does not turn them off like it is supposed to for the reset.
If I turn the controller off then turn it back to Auto the lights go off and then in 15 seconds or so the generating light comes on as it should
within 15 min that goes off and I get the two lights inspect cell, check salt again. My salt reading said 6000 before cleaning the cell, which is crazy and impossible. I had the water checked and it was 2300 still a little low. I just added two bags of salt this weekend as well. After cleaning and re installing cell the 6000 number went away. I have plenty of chlorine in the pool, so something is making the chlorine., I have added no shock at all. now today my salt reading is 1200 I don't get it.
How can you tell if the SWG is bad ? no calcium build up at all. Why would the generator work , then constantly re set. Is the computer bad ?
Circuit board. Is there a reset for the Aquaright unit to re calibrate itself ? nothing in the owner manual.
My water is perfectly clear too. I live in Fresno, and it is plenty hot here to zap chlorine, but that does not happen. any suggestions as to how to make the generator stay on and and make salt. I don't think adding 5-8 bags of salt is the answer
any input is appreciated
chris
chris
