I've noticed that my initial read of pH is coming up low, the color is more yellow and tests about 7.2 - 7.4. I know my pH is not that low, so I retest. Using same water source (I pull water from pool in cup) the 2nd read shows what I expect it to be (7.6 - 7.8, or higher). This does not happen every time, but it has occurred frequently enough that I thought I'd look for reason. At first I thought it may have to do with residue from the chlorine test, but I now rinse and dry the tube after the chlorine test which I would think removes any residual chemicals. Any ideas on why the first reading would be so different/low?
