I'm almost embarrassed about asking this question because I've been maintaining my pool the TFP way for many years now but I wasn't able to answer this question. I have a CYA level of 50 and keep the chlorine level between 5 and 6 and all has been well (glossing over the PH, TA and CH) but today my wife asked me if I could get a cheap tester just to test the chlorine. I said no because they don't test at levels higher than 5ppm and that reminded me that most websites suggest a chlorine level of between 1 and 3ppm when using chlorine tablets. (like this one Chlorine Level in Pools: What is the Proper Level?).
If I let my FC level drop below 3 my pool will turn green but if I believe these websites and use chlorine tablets it should be fine with a level between 1 and 3? How does that work then?
The other thing that doesn't add up is that if I use chlorine tablets my CYA levels will rise which means I have to raise my chlorine level to suite. So if I switched to using chlorine tablets I would need to keep my FC at 7 then 8 and then 9 as my CYA levels increase. So why do I keep seeing FC levels of between 1 and 3 for tablet use, it doesn't add up, what am I missing?
