We were changing over to SWCG and before adding salt, we found we had extremely high CYA level tested at 2 different pool supply companies 150 ppm, plus a paper strip test. The pool has been maintained weekly by a pool service so we never checked the numbers until now. We have just ordered the TF-100 kit online XL plus salt strips, so we can start taking care of the pool ourselves.
‘Our new Hayward SWCG manual states that it is a special requirement to keep the CYA level between 30 to 50 ppm, ideal level 40 ppm. I notice your recommendations for SWCG pools is a much higher CYA level of 60-90 ppm. Why is your recommended level so much higher?
We started doing the drain and fill to reduce the CYA level. The pool supplier tested it today at 125 ppm.
We also noticed last night a big glob of stringy, slimy whitish/gray material around the pool/skimmer area. It fell apart when trying to remove it. I captured a piece of it and will attach a photo. Is this white mold?
Here are our numbers today from pool supply co.
Tc 3ppm
Fc 3 ppm
Cc 0 ppm
Ph 7.6
Ta 125 ppm
Ch 450
CYA 125 ppm
TDS 1400 ppm
Salt 800 ppm
Should we be adding chlorine for possible mold, while draining and filling process is going on?
I am so glad glad to have found this site and forum! I really appreciate all the information and assistance.
Tc 3ppm
Fc 3 ppm
Cc 0 ppm
Ph 7.6
Ta 125 ppm
Ch 450
CYA 125 ppm
TDS 1400 ppm
Salt 800 ppm
