Hello and welcome!
Are you able to capture them in a net / etc.? Gather a bunch of them up into a pile? If so, try putting a little muriatic acid on them and seeing if it fizzes.
My pool net doesn’t pick it up if I do the acid and it fizzes what does that mean thanks for the response
Yes that is what it looks like I have never has this problem before could it be because my calcium is low do you think the pool store will know what it isBecause our water is up over the skimmer right now, I have this whitish/semi-translucent stuff floating on my pool surface too. It's too fine to get with the skimmer and it's mostly pollen and fine debris that's blown in. It's hard to see unless the sun is reflecting on it. Is it like this? When my skimmer is working properly, it mostly goes away.
You don’t need to worry about low calcium in a liner pool. If it’s organic, keep your pump and skimmers running and let them take care of it - make sure your FC is right per the FC/CYA Levels to ensure no algae bloom and let the filter take care of it.Yes that is what it looks like I have never has this problem before could it be because my calcium is low do you think the pool store will know what it is
