So I believe I have determined a white mold issues in my 400 gal sundance spa. Chlorine system. Has clearray. I use granular daily as needed and check and keep my levels pretty on point most of the time. This is a daily effort though and my schedule leaves some days at a time without ability to tend to the spa.
We tried "Frog ease", well my wife found it an bought it, which worked relatively well, but white mold came back again hard.
I just did a high level of chlorine for around 4 hours to hopefully wipe it out, drained, cleaned by hand, refilled enough to get jets under and did a 2nd high chlorine clean session. Drained it all and started over.
This appeared to work for about 3 weeks and back to the same game. I have ditched the frog ease system this time and went back to daily dose work as i had no away time planned. 3 weeks later its cloudy, but no flakes. All levels look good, and have stayed good in my spa(Using Taylor test system, not strips). Just go off their "Spa" Guidelines for my balance. I have cycled my filters once per week at this time as well thinking it needed to grab some residuals that are breaking up. I clean my filters with a filter cleaner every time and dry in the sun.
I ordered the Ahhsome that most appear to agree with is a great tool for a proper clean out. I think ill give it two treatments at this time. I ordered a new filter as well and will toss the old one just in case theres some sort of white mold growing in there.
Any thoughts on something additional to do? This spa is used about 5 days a week consistently in the evenings, i usually toss a little granular in afterwards every use (Tablespoons worth). When im out of town, it always zero's out though and causes issues. Any thoughts on using a floater and 1" tabs when im in this situation to keep it sanitized?
