- Apr 5, 2022
- 95
- Vinyl
- Hayward Aqua Rite (T-15)
Wanted to see if you guys have any advice on what this is, if it can be fixed, and how to prevent further damage.
We are now entering our 4th year with this pool and vinyl liner. I noticed about midway through last year a few white marks along the waterline on the liner. I'll attach pics below. This year, I've noticed it a little more. It's only happening mainly on one corner of the pool. That corner does have the most wind flow and probably ends up seeing the sun the longest. The cosmetic part is a concern, but I'm mainly worried about it potentially getting worse and actually cutting through the liner. On my 3rd picture, I actually tried rubbing the white spot with my finger and instantly it sort of moved the white stain and filled in more area/made it worse (you can see it in the more circular area)
Any ideas on what the heck this is? It isn't anywhere but the waterline and maybe even slightly above the water line? Nowhere else but there. We do get heavy winds that would occasionally blow any organics floating on the top of the pool over in that area (but it isn't much) and that also probably ends up being the hottest area of the pool with the sun hitting it the longest. I have not tried to use anything other than just water to clean that area of the liner. Not sure if anything would help.
I've been very good with keeping pool clean (use a robot daily) and balancing/chemicals. Pool has been at the optimal levels 100% of the time during the last 2 seasons. For reference, current data (using the TF-Pro with new reagents this year)
FC 6.0
Salt 3000
PH 7.5
TA 60
CH 125
CYA 60
I don't believe I have any mineral issues. Tests were good about 2-3 years ago on all minerals (that one was a pool store ran one though) and I know for a fact I've put in no minerals (copper, etc.) since that time and about half the pool ends up drained each season with rain etc. We have normal city water (not well water).
Appreciate any help on what this is.
FC 6.0
Salt 3000
PH 7.5
TA 60
CH 125
CYA 60
