- Nov 12, 2017
- 11,912
- Plaster
- Pentair Intellichlor IC-40
I just noticed some white flakes just below all three of my returns. Half inch or so in size. Exactly the kind I used to get when my SWG was in use. But it's not currently in use. Not even powered on for any part of the day (I pulled the fuse a month ago). Water is balanced. CSI is great, and has been since new pebble startup in October. The only thing that's different is the two cups of CYA I put in last week. Filtered well through a sock, half directly into the pool, the other half into the skimmer. I haven't tested for the new CYA level yet, I've been waiting a good amount of days to get the most accurate reading. Ideas? Could the new CYA loosen old flakes off the SWG plates?
Some results are from previous days' testing, I can do a fresh set if need be:
--edit--
Oh, and it's finally been raining these past couple of weeks...
--edit--
