- Jun 25, 2021
- 28
- Vinyl
- Hayward Salt & Swim 3C
Just opened the pool a couple of days ago, algae has started to clear. But when I got home from work today there is a white film floating on top of the water which I’m not sure what it is. Had the water tested 2 days ago at the local pool store, salt level was low so added another 70lbs of salt as per the test. Just used test strips now:
PH a bit low at 7
FC 3
Total Alkalinity 80
Stabilizer 30-50
Wondering if anyone has an idea of what is causing the film?
Picture below but it is a bit difficult to see
EDIT:
I had the SWG on fairly high, turned it down to low right before this post and the film cleared within 10 mins. Problem with the SWG? Or just too high of an input?
PH a bit low at 7
FC 3
Total Alkalinity 80
Stabilizer 30-50
EDIT:
