Problem: There is a white film on the surface of the water. Not sure if this is algae or something else is going on with the water.
The pool started getting this white film, and we thought it could be related to not having enough chlorine due to the CYA level.
Originally, the pool store sold us chlorine tablets and shock that contained stabilizer and we did not understand that this could cause issues with our pool. In the last week we stopped using the tablets and changed to Bleach. The CYA level was 160 (used Taylor K-2006C) so we pumped out some water and refilled it and now it is at 100. We are thinking to dump more water out to get it even lower. We have been trying to keep the chlorine levels higher due to the CYA levels. The pool place told us the chlorine levels should be 4-5 since it is an indoor pool, but now we know this is not true using the TFP Pool Math app.
We have this weird white film on the pool that we cannot get rid of. Does anyone have any recommendations on what we should do to eliminate the white film or any other things we should be fixing based on our levels?
- FC: 9
- CC: .5
- pH: 7.2
- TA: 110
- CH: 60
- CYA: 100
- Phosphate: 1401 (test from Aug 26 at pool store)
- My pool: indoor vinyl inground pool - 14,200
- Pool chemicals: chlorine
- My pump & filter: Variable speed pump, Cartridge filter, UV and Ozone (DEL AOP 25)
- Other info: Automatic pool cover
