WHISPERFLO PUMP UPGRADE
paulus delamarus
In The Industry
May 25, 2022
3
phoeniz arizona
I just purchased a 2.7 hp vgreen replacement motor for my whisperflo wfds-6 two speed 1.5 hp pump
the parts list for the wfds-6 shows a 073129 impeller,
for the 2 hp whisperflo the parts list shows a 073130 impeller
for the 3 hp whisperflo the parts list shows a 073131 impeller
The replacement impellers are about 35 $
for the 2.7 hp vgreen replacement motor, should I replace the impeller or stick with the 1.5 hp 073129 impeller in the pump?
The largest you could possibly use is the 073130 impeller (2.60 THP). You have to remember that label HP <> THP.
The only advantage is that you would be able to run at lower RPM for the same flow rate which results in lower noise.
Impeller......Total HP.
073126.........0.95
073127.........1.25
073128.........1.65
073129.........2.20
073130.........2.60
073131.........3.45
The total hp is the rated hp x the service factor.
