I have an older whisperflo pump and 1.5hp motor. I’ve replaced the motor once already and now the motor bolt mounts on the pump itself seem to be stripped out.
Is there a more efficient, quieter pump and motor I can replace this with? Will a variable pump work with my existing Pentair easy touch control panel, which currently controls the whisperflo pump, booster pump for the bottom cleaner, and other things like fountains, etc.
Wondering if something like this variable speed pump would work, but don’t know if the built in timer would be compatible with my existing control panel.
