Hi guys!
This post is kind of a continuation from Clearing a blockage in the skimmer line
Basically, I blocked my pool because I didn't use a skimmer basket (new to this whole thing!).
I've pulled the concrete up and removed the blockage - there were some spring loaded non-return valves such as these (Holman 20mm In-Line Check Valve) that were blocked.
A pool guy told me to just remove them as they are not necessary and probably shouldn't have been under the concrete in the first place- so we did.
As you can see in the photo in the yellow box, we have just replaced it with straight pipe.
In the red box, you will see also a manual valve. That originally used to be a check-valve (one with the flap) but my pool guy replaced it with the handle driven one (can't remember why- i think it was meant to be temporary).
So, changes from original setup now are that we don't have the spring loaded in line non-return valve and the check-valve that goes into the filter pump is now a manual one.
The issue I have now is that both pumps don't stay primed.
So, obviously these parts are needed.
Does anyone know, if I was to just put a check valve in above the concrete (where it was originally), will that be enough to keep it primed, or do I actually need the spring loaded inline valves in the ground?
All of this is above water level.
I'm also curious why the solar pump never had a check valve on it
