Hi all,
I have been out of the country for work and haven't had the chance to check water in awhile. While I was gone, we had rain for a about 4 days. I did my numbers this morning and have some troubling results. I'm wondering if experts, here, can tell me which troublesome number to address first:
My readings (I think these might come up in my signature):
Free chlorine: 8PPM (Just added 30 .oz of liquid chlorine/10% last night)
Combined chlorine: .7. The TF100 test didn't quite clear at one drop of R-0871 (though it was nearly clear). So I put one more drop.
Total chlorine: 8.7
PH: 7.8
TA: 100
CH: NA (AGP)
CYA: ~10 to 20
I assume the CYA is the biggest issue. I have a solar blanket on the pool now but plan to clean the debris from pool bottom and, once I have numbers at acceptable levels, cover the pool with the solid cover.
Please let me know if I am correct in addressing the debris and CYA first and if I should retest chlorine stability following CYA. It appears I need to add 23 .oz of CYA (I'm using dry powder). How long should I run the pump - until dissolved or for a fixed time?
(Adding note: it's between mid 60s as a daily high to high 30s as a low, here, right now).
Thanks!
Total chlorine: 8.7
PH: 7.8
TA: 100
CH: NA (AGP)
CYA: ~10 to 20
Thanks!
