Hi
I much prefer liquid chlorine. I bought a stenner Econ T. I have a variable speed pump that runs 24/7. The pool builders already tapped the lines twice…One on the auction side, in on the return side. I use these to blow out my lines during closing.
I plan on using 12% sodium hypo. I shouldn’t put it into the suction side because it can damage my equipment?
The tap on my return side is in line with my tanning ledge “fountain” which is just a small pvc return. I don’t have this valve open most of the time, but if I do and run the chlorine line there, it might hit my auto cover and bleach it. If I keep that valve closed, because of the plumbing, will the chlorine find its way into the other returns?
Or should I just tap somewhere else?
Thanks!
See pic
Thanks!
See pic
