reggiehammond
- Oct 4, 2020
- 1,558
- Plaster
- CircuPool RJ-60 Plus
I think you’re delaying the inevitable - you need to SLAM and get the water sanitation in order. That will kick up more dead algae cells, but what’s different than what you’re doing now? Even if you have to break down the filter a few times over a week, it’ll save you a lot of time, effort, and money down the road.It will help a little, but then a week later I'm right back in the same spot. Less if I'm scrubbing anything. A fresh cartridge I'll get a month out of.
I checked and the filter is good for 2.5x what I think the volume of the pool is. I even bought a hose attachment for spraying the filter out. That helped tremendously... but it's still a PITA compared to backwashing.
Look into a filter flosser on Amazon - pull the cap off the cartridge filter, remove drain plug, and you can clean 95%+ of the filter cartridges without removing anything else.
