Hello everyone,
Purchased a home with older automation equipment. I have an Intellitouch panel inside and pretty sure an i5 outside (and a spa controller if that matters). Looks like firmware version 1.090 inside (UIC) and 1.160 outside (UOC).
I have an Intelliflow VSF pump. It is set up for External Control.
I have figured out how to change the programming for SPA (set up as egg timer for 3 hours), POOL (day/time) and HIGH SPEED (day/time, I'm assuming this is a custom set button) on the Intellitouch.
When I press the POOL button (or when its the correct time to run the POOL function) the Intelliflow pump will say "Prog 1" and will run at whatever speed I have set for Prog 1 in the setup on the pump. When I press the HIGH SPEED button (or the correct time for that function) the Intelliflow will say "Prog 2" and run at the (higher) speed I have set for Prog 2.
When I look at the programming on the Intellitouch, Menu-Setup-Equipment-Intelliflo- I have a screen of Intelliflo 4 pumps to select, but it appears there is nothing set up for any of the pumps.
While I can adjust the scheduled days/time on the Intellitouch, and the pump speeds (at least for Prog 1 and 2 under External Control) on the Intelliflow, how does the pump know to run Prog 1 for POOL and Prog 2 for HIGH SPEED?
I'm not looking to borrow trouble, since right now everything works, but the engineer in me wants to know! The previous owners left all the manuals but not sure how to decode any of the programing.
Welcome any thoughts or where I should look for this logic.
Thanks!
Thanks!
