- Apr 17, 2017
- 52
- Plaster
- Pentair Intellichlor IC-40
How do I know if my Intellichlor ic40 is really producing chlorine as it should? The unit is about 4 years old, my salt level is good, all the lights are green, I'm running it at 100 percent output, I have even cleaned it with acid and there is almost no buildup inside. So why is the chlorine level in my pool low to undetectable???. I've been testing my water every week and dumping different chemicals (and salt) in to get everything at the proper level. My last visit to the pool store showed these results:
38,000 gallon pool
chlorine: 0
cyanuric acid: 70
total alk: 90
calcium hardness: 180
salt: 3,000
phosphate: 500
and Since that visit I added:
25lbs conditioner (to increase calcium hardness)
40lds salt: to bring that up closer to 3,600
2 qts phosfree: to bring phosphate down
I also acid cleaned the cell (never did it before so it was the first time)
but 3 days later still cannot get any pink on that strip! After reading a bunch of posts I'm starting to suspect it might have to do with the total amount of running time. The pentair intelliflow pump is running 12 hours per day, the pump speed is set at 3, the ic40 is set at 100 percent output, and the pool is 38,000 gallons. Is it not enough time? Thank you for your help!
38,000 gallon pool
chlorine: 0
cyanuric acid: 70
total alk: 90
salt: 3,000
phosphate: 500
