Hi,
I need help narrowing down the location of air leak in my inground concrete pool system. Attached image shows the system. Water from two skimmers go into the pump via a jandy valve. Pump doesn't have any air bubbles. So, it doesn't look like a suction-side air leak.
Is the filter introducing these air bubbles? What should I check/fix there?
And if it's not the filter, what are the other possibilities?
Thank you!
Thank you!
