Hi all! So I’m new to this pool thing. I have an 8ft summer wave pool that I am currently filling up. Do I add chlorine tablets after the pool is filled? And where Dow’s PH come from? Is PH already in the chlorine?
Ok thank you. Can I use household bleach? And how much bleach would I need for an 8ft 608 gallon pool? Thank you?Shy,
Tablets are a challenge to use on seasonal pools. TFP recommends the use of liquid chlorine bleach. Your best bet is to follow the steps outlined in the following guide:
Guide for Seasonal/Temporary Pools
Smaller seasonal pools can see just as much enjoyment as their larger counterparts. In this guide we'll show you how to maintain your temporary pool.www.troublefreepool.com
After filling, add 30 ppm of chlorine stabilizer (CYA) and add enough chlorine to raise the chlorine level (FC) to 4 ppm. Use Pool Math to determine how much of each to add.
Let us know if you need help getting your feet wet.
Do I have to have stabilizer for my pool water or can I just add more bleach when the chlorine has been used up? Thank you.More on pH...
PH - Further Reading
Yes I have the OTO test kit and the strips. When do I add the stabilizer to the water? And is stabilizer added everyday? Thank you so much.Stabilizer is needed to protect FC from being burned up by the sun too quickly and it buffers the more harsh effects of the chlorine.
You can use plain unscented household bleach, but it may be a challenge to find. Best is to find liquid chlorine at Home Depot, Lowes, Wal Mart, Ace etc. It's sometimes marketed at "chlorinating liquid" or "liquid shock." Liquid chlorine is sold in varying strengths from 6% to 12.5%. Most pool chlorinating products from the big box stores are 10%. How much to add depends on the strength.
You'll probably need to add chlorine daily to maintain FC levels. Your pool may require up to 4 ppm per day. Do you have a test kit?
For a 600 gallon pool, you will only need 3.1 oz of 10% liquid chlorine to increase FC by 4 ppm.
Ok thank you. It’s really not easy to take care of a pool the nature of water is brutal.Welcome Shy.
pH is not something you add, is is a measurement of your water. Pool water should be neutral and in the 7s and between 7.1 and 7.9. A lower number is acidic a higher number is basic and both are not good for swimmers, equipment and sanitation. We use muriatic acid to lower pH and baking soda to raise pH. You will need a test kit to manage your pool and keep it safe.
Safe pool water is a balancing act and requires periodic testing.Ok thank you. It’s really not easy to take care of a pool the nature of water is brutal.
I am just about finish filling up the pool. Should I test the pool water before adding chlorine and the stabilizer?Safe pool water is a balancing act and requires periodic testing.
Tell us more about your source water and your testing results.
How do I know if I’m adding 30 ppm of chlorine stabilizer? I suck at math sorry.Shy,
Use this app. Just fill out your pools information (volume ect. ) and it will tell you how much to add based on testing.How do I know if I’m adding 30 ppm of chlorine stabilizer? I suck at math sorry.
Beat me to itWe use Pool Math to estimate chemical additions... PoolMath
In a post above Rancho estimated your pool volume at 600 gallons, is that correct? If so he also calculated your stabilizer and chlorine additions.
Measure the pH of your fresh water and post the result. Besides Chlorine what else can you test now?
