Re: Where do you buy your parts for rebuilding pumps and mot
For example, my similar leak above was solved with a shaft seal.
I could have sourced the replacement using a standard 3/4" PS-201 Buna rubber shaft seal (Pentair P/N 37400-0027S) but the upsell was a Viton PS3868 (Pentair P/N 37400-0028S) shaft seal.
In keeping with the trade-size suggestion earlier in this thread, by sourcing trade sizes, instead of Pentair part numbers, I was able to fix my leak using the better Viton seal for about 1/2 the common price of the standard Buna (aka Nitrile) rubber seal.
You may also wish to note though, that the pool stores (e.g., Leslies) will put the shaft seal in properly for you for free - so, they do provide a valuable service if they're local to you.
EDIT: I see you opened a separate thread on this; so I'll jump over to there.
BTW, the divergence of prices is even wider than shown above, if you include the resellers in the mix:
I ended up buying four seals at hottubwarehouse since the price was so good:
It sounds like you need a shaft seal, and not an o-ring.dkellerd said:Can someone help find what o-ring I need for this motor?
