Where do I drill the 3/8-in hole for the water sensor?
After filter. Green dot is best or yellow dot is also good.
Sorry, but I'm super confused now because Rocket Squirrel said between pump and filter, but ajw22 says between pump and heater?!?
Between the filter and heater. After the filter so that no debris coming through the pump damages the sensor.
Un-pro tip: Don't use a drill (like a brad point) that can create a little 3/8" disk as you punch through at the end. Since you are past the filter, this can cause mischief with valves, return eyeballs, etc. Don't ask me how I know. Best is to remove the pipe completely at the unions - which looks possible in the pics - and flush clean before re-installing.
I don't understand what you mean. Are you saying remove the entire pipe section from the unions, drill a hole, and make sure there's no PVC debris inside the pipe and then reassemble?
Yeah if there is any concern that drill debris can cause problems downstream. Probably overkill, but undoing/redoing a couple of unions should be 2 minutes. The main thing is to use a drill bit that doesn't punch out a disk as it breaks through.
3/8" Brad Point Bit - bad
3/8" Paddle bit - good
Ok, so I disconnected the unions, drilled the 3/8" hole and removed all debris before reconnecting...I hope this is the right spot.
Reactions: generessler
