- May 3, 2014
- 58,891
- Fiberglass
- Pentair Intellichlor IC-40
Hard to call from pictures, but I would call it 50 ppm CYA based on the pictures.
I would suggest you go to maintenance mode and see what the FC acts like. Use the target range FC for 50 ppm CYA. Test the same time each day and add what is needed to raise your FC back to target range. See what your FC loss is each day. After several days, report back.
