Hey ya'll,
Had a quick question I was thinking about as I was adding some acid tonight to lower my pH. First, here's my latest test results:
FC: 4
CC: 0.5
pH: 7.9
TA: 60
CYA: 30
CH: 150
Borates: 50
When I use the effects of adding tool in PoolMath, I can see that the 1 oz of MA I added to bring pH down to 7.6 is estimated to bring TA down by 9. If I do this a couple of times, my TA will presumably be below 50. I was curious if when I'm approaching the lower end of the acceptable TA level (I've heard it could be as low as 40) if I should go ahead and add enough baking soda to offset the TA decrease shortly after adding the acid. Or if there's another approach I should follow to make sure TA doesn't get too low while adding acid to lower pH.
I guess another question is if I'm finding my pH is pretty stable at 7.9 if I even need to try to bring it down to 7.6? The sticky says 7.8 is the max so that's why I've been trying to keep it under that and closer to 7.6.
FC: 4
CC: 0.5
pH: 7.9
TA: 60
CYA: 30
CH: 150
Borates: 50
