- Jul 21, 2013
- 65,575
- Plaster
- Pentair Intellichlor IC-60
Test your FC in 30 minutes and see if you have a FC of at least 6ppm.
Just so I'm understanding the process and sometimes its challenging if to follow things literarily or make common sense assumptions (which sometimes isn't always correct).Assumption is not reality. Do not rely on the robot.
Test your FC 30 minutes after adding.
OK, I was of the assumption taking measurements was point in time to see stabilization levels vs. 30 min check and then by end of day it's something completely different. I didn't realize this was something that required this frequency of testing unless this exercise is to check how fast it is being consumed/burn off which then makes sense.
I'll go check now.
Remember I had the socks of CYA in last night.All you needed to retest was your FC. Although we see you picked up another 10ppm of CYA.
You only need to retest the chemicals you affected with your addition.
Why have you not lowered your pH?
Also, I did add the MA that was recommended this morning. I guess it is asking for more now
