When is it OK to open a pool in Long Island
Mandrake
22
Setauket
Hi,
With Spring rapidly approaching, I am itching to open my pool soon. I usually open it in the middle of April (I have a mesh grid cover, so it takes 2-3 weeks for water to clear), but I am thinking of opening it sooner this year, maybe even towards the end of March. I have a gas heater and due to pandemics, we are staying home, so I was thinking that maybe I can start using it in April.
I also have a solar heater on the roof, but I am not planning to use it until at least May 1st (to make sure it does not freeze and destroy the panels).
Is there any drawback to opening the pool early ?
Thanks!
Reactions: Heavenlytunes
Newdude
9,134
NY
Hey Mandrake !! So here’s the deal for us. The spring is all over the place. Today was almost 70 so those thoughts start creeping in, but it will cool off again and possibly even freeze for a while. When it is really *time* it will of course be cooler and ‘Meh, I can wait 3 more weeks, it’s too chilly to want to swim anyway’. BOOM, swamp. That’s what happened to me last year. I opened ‘early’ per the water temps but way too late for all the warm days we had here and there.
You’d be best opening soon and if we happen to get a cold spell, just run the pump for the 3 days it’s bad. Or it warms up altogether and you are ahead of the game.
Mandrake
22
Setauket
Thanks Newdude,
I am perfectly fine not swimming if the weather is bad - I like the view of the open pool way more than I like it covered :)
I just want to make sure I don't ruin anything with opening too early. I was particularly concerned with the solar heater (since it's thin), but I guess if I don't get the water up there I should be fine. I have a variable speed pump, so I can run it for days, no problem.
zea3
13,916
Houston, Texas
If you are certain you have seen the last of the hard freezes in your area you should be fine to open the pool. A few hours below freezing can be managed by keeping the pump running. If you expect a few days where the temp never rises above freezing then you may want to stay closed a little longer. Look into what the expected long range outlook is for your particular area before you decide.
Newdude
9,134
NY
Nope, nothing to ruin. In 2 weeks or so we should be over the hump for any extended freezes. If we get an oops, you won't even know the pump ran for a few days. I ran my VS pump 24/7 for about $20 a month
I always preferred looking at the water too so I inadvertently opened really early every year with clear water. Last year cooled back off in the early spring and I waited because of it. I still opened early, just not super early and I was punished.
The solar cover won't care either. :)
Mjwall82
68
Long island ny
Autopilot Digital PPC1 (RC-35)
I’m on Long Island also and the weather these past few days has me thinking the same thing. Looks like the weather will be cool again for a little bit but I’m thinking that I’ll open on the next warm weekend we have. Or the first week or so in April. Whichever comes first. A little nervous about my first time opening it up, since it was built in May. But, this site has me confident that I can do it. 💪🏻
l1ltaral1l
618
Walnutport, PA
Hayward Turbo Cell (T-CELL-5)
We just put it on the calendar to open the weekend of April 3. I was really pushing for end of March, but I'll settle. HA! I can't wait!
Newdude
9,134
NY
Do you think that if I had opened on one of those 70 degree days that I would be fine running the pump 24/7?
Oh yeah. It will take longer for the water to get to freezing than the cold blast is gonna last. You probably wouldn’t have even needed to run the pump today because your water is still well into the 40s We should be done with the worst of it in another week or two.
wireform
In The Industry
Aug 15, 2017
2,590
Spring Valley, NY
Opening is much easier then closing. You need to know the pool equipment and understand what needs to be buttoned up before powering up. Make sure you understand the valve positions and what goes where. Very important make sure not to dead head the pump otherwise you can damage stuff. Have o ring lube on hand too. The rest is easy.
Mjwall82
68
Long island ny
Well I took pictures of the equipment pad and valves before it was closed and I just ordered some O ring lube. Maybe I’ll start a thread once I’ve got everything in place and ready to turn on just to make sure I’ve got everything correct.
JJ_Tex
2,500
Prosper, TX (DFW)
Pentair Intellichlor IC-40
All my NYC coworkers were talking today about being sad that "first fake spring" was over, but happy that they are one step closer to real spring.
Reactions: Snoobug and Newdude
Mjwall82
68
Long island ny
@Mjwall82 , your link is messed up.. but if I am looking at what I think you are trying to show us. it looks silicon based and should work
Thanks! I ended up just cancelling it and ordering the magic lube II that’s recommended in the article. Better safe than sorry.
