My water is clear and it passed the overnight chlorine loss test, but my combined chlorine is 14.
What do I do next?
I started this Sunday BTW.
Thanks
What do I do next?
Thanks
We're not speaking the same language, I think.I never used any non chlorine shock and I did the test twice. If I’m understanding correctly, I was supposed to bring the chlorine level up to 20 and keep it there correct? Now it’s at 14.
Awesome!If your water is crystal clear (think calling heads or tails on a coin laying on the floor of the pool) and you had no overnight loss and a CC of 0, you’re done!
Are you sure, now?I’m using a TF-100. Last night my FC was 14, this morning it’s also 14. The CC test remained clear this morning.
I may have misunderstood. When I did the CC test it was zero. Is that the number you go by or do you add the FC number to the CC number?Are you sure, now?
If the water is clear AND it passed the OCLT AND the CC is zero, then you're done. The next step is to let FC drop below 10 and run all the tests and make adjustments based on what you find.
I'm still wondering why you posted "My water is clear and it passed the overnight chlorine loss test, but my combined chlorine is 14."
